Re: Can't choose ASIO as a hardware out - M-Audio MTrack 2x2 (windows 10)
Posted: Fri Dec 11, 2020 10:12 pm
Similar situation here. Using Motu M4; the layout is:
Mic on 1st input;
audio from Transceiver ( amateur radio ) on inputs 3 & 4;
Audio from transceiver is mapped into A2 - channels 1 & 2 out on Motu (also headphone ); and onto B1 - virtual out, fed into software on PC to process and decode ( think of it as DAW
Mic is routed to A2 for monitoring , and to A3 - which is outs 3 & 4 on Motu, fed into transceiver as audio input.
Desktop audio ( Spotify, etc ) is fed via Voicemaster VAIO into A2-- MOTU chan 1& 2 > headphones.
Software/DAW output is routed via Voicemaster AUX -> into outs A2 and A3, first is Motu 1&2-> headphones, second is Motu 3&4 -> into the transceiver.
Just like you, when I set A1 to ASIO Motu, nothing was heard. I added mapping in System setup - image attached - and now A1 for some reason does nothing; but I have outs on A2 and A3, mapped via ASIO. So I'd recommend to map Out A1 , A2 A3 - as per the yourtube and as per attached image - and see if it will work for you.
I am confused why enabling ASIO as A1 forces me to use A2 & A3 for outs 1,2,3,4 on Motu, but obviously I am still having troubles with understanding ASIo routing.
BTW, - I was able to load config from banana into potato - it ignored non existent interfaces, but everything else worked.. nice !
Thanks, good luck.
KU1T
Mic on 1st input;
Thanks, good luck.
KU1T
