Macrobuttons for Hardware Out possible?
peejaygee
Re: Macrobuttons for Hardware Out possible?
Post by peejaygee »
I tried it once more, I screenshot the setup.
You'll see the red line that is flashing, I copied it from the first quote to the second quote, incase there were any hidden spaces, etc.
I've tried it with Bus(0).Device.wdm and Bus(0).Device.WDM
Still didn't work.
ok, i'm going to check the process behind...
peejaygee
Post by peejaygee »
Vincent Burel wrote:ok, i'm going to check the process behind...
Ok, keep me posted, and if you need any logs, tests or anything, just let me know.
In the meantime, I'll just stick to manually switching. :)
