Re: Voicemeeter does not work well with Realtek card/drivers causing system audio feedback as mic input
Posted: Tue Jun 09, 2020 3:54 am
It's possible that part of my issue was related to something that voicemeeter does when it puts the drivers in Virtual I/O mode. I can't really confirm, but if whatever was causing OP issue was related, then this information may help Vincent if he puts much effort into researching this further if he thinks it is necessary. I also hope that this message (paragraph three in particular) will help the OP with original issue. Please PM him if you want. I'm not sure he is still reading this thread and I can't yet send PMs.
I solved all of my issues. I noticed that when attempting to uninstall the voicemeeter devices from the device manager, they reappeared. I dug further and found a stray vac driver still installed (not ABCD). I removed it and all the voicemeeter devices also went away. Just to make sure I covered all the bases, I uninstalled realtek drivers, reinstalled newer version from mainboard site, rebooting when necessary. It no longer mixed audio into the realtek mic interface, but it did continue to mix into the usb mic interface.
I found a setting I didn't notice before after installing the new realtek driver package. It may be something new but I can't confirm this. "Separate all INPUT jacks as independent INPUT devices" I ticked this and the system reverted back to how it was working before. It seems that somewhere along the way, this setting was overridden/disabled (potentially behind the scenes if this wasn't available on the interface before the upgrade). I rarely use that software interface, so I suspect some automated thing told the board to mix the mic interfaces, which somehow told the system to mix in the output device along with the mics. I suspect ticking this setting reset whatever was going on to cause the I/O mix. What perplexes me is that whatever happened hear affected a non-realtek usb device. I will keep an eye on this to ensure it does not revert. I will make note of when it begins.
If I didn't mention this before, the VAC control panels showed stuck in Virtual I/O mode even when voicemeeter wasn't running and even after uninstalling it. Normally when voicemeeter closes, this setting is reverted for all three devices. This no longer happens after the reinstallations. My suspician is that things became unstable through one of the upgrades uninstalls/reinstalls of voicemeeter when I was first getting started with it.
Lastly, I have been using VAC since Feb 2009. I've been doing audio engineering as a hobby and sometimes professionally for quite a few years and I'm also a 25 year professional IT veteran. Going straight to "reinstall the OS" is a dangerous thing to recommend people on these forums based on the simple idea that valuable time is being wasted otherwise. Vincent even says you shouldn't need to except as a last resort. If I didn't know this wasn't necessary in my case, I would have been stuck reinstalling all my licensed professional audio software along with some rather large games and professional astronomy, photo, and video editing software, which would have set me back several weeks. Please reconsider making this your default recommendation for people. Most of the people visiting here probably have more complex configurations than a simple 2 to 3 hour OS reinstall. Many of them are likely audio folk with fobs and licenses and other issues that have to get sorted (some of which do not migrate to new OS installs without a lot of effort dealing with the manufacturer). Anyway, thank you for taking the time. I do appreciate your willingness to assist people. I just think a little more caution should be observed when making recommendations.
Vincent, if you make it past my wall of text, thank you for the many years of VAC. No audiophile should be without it. Cheers.
