Live interviews with Skype and Mixxx via Banana
RaVlaNa
Re: Live interviews with Skype and Mixxx via Banana
Post by RaVlaNa »
Believe me, that is EXACTLY what I am doing, but when I run Skype, all I hear is a bit of crackle.
ha, could you post again the screenshot of your
- Voicemeeter System settings dialog box
(do you have changed parameters in VB-CABLE Control panel ?)
RaVlaNa
Post by RaVlaNa »
OK, here is the screenshot:
I have not touched anything in the cable control panel, so it should be exactly as it was at setup.
ok, so now the Skype caller sound is coming in Voicemeeter input #2 through the VB-CABLE.
Assuming the sound is bad only on input #2, (not on your MIC too) you may try to select other VB-CABLE interface than MME (try WDM or KS) to see if it changes the things...
you can also try to make a re-selection of audio devince in Skype Sound Dialog Box, to confirm the choice and check that you have not the same device twice in the list...
for the moment i see nothing else...
RaVlaNa
Post by RaVlaNa »
Vincent,
you will probably not believe this, but I had to set INPUT #2 to VB Audio Point (What exactly is that?) and Skype speakers to VB-Audio AUX, and then I finally got signal in VIRTUAL INPUT 2.
So, I finally got it working.
When the woman on Skype speaks, I still have to turn my mic up in Mixx, but that is most probably not a Voicemeeter issue.
But, hey ho, Hallelujah, looks like we finally managed.
If there is anything strange you noticed about the way it was solved, please let me know.
Thank you for all your help.
ha, good to see you finally found a solution!
