When I import an audio file into Reaper and use the Focusrite 2i2 asio driver I get wonderful audio output with the buffer set to 256 samples.
However I would like to play the file from Reaper through Voicemeeter (as proof of concept) so ,with the Focusrite driver as A1 in Voicemeeter Potato and with Reaper using Vaio3 Asio, I route Vaio 3 virtual through A1. The audio is truly awful sounding as if the singer is gargling at the same time. I tried increasing the buffer but even at 1024 samples there is little improvement in the audio. I don't know whether the fact that I am using the 64 bit verison of Reaper is a factor! Can anyone give me any advice please.
TIA
John
awful sound quality from Vaio 3 asio in Reaper
john9dpr
RobBoss
Re: awful sound quality from Vaio 3 asio in Reaper
Focusrite ASIO drivers are known for inconsistent reliability issues, also in conjunction with other applications besides Voicemeeter.
viewtopic.php?f=6&t=978&p=3279&hilit=Fo ... 16f9#p3279
viewtopic.php?f=6&t=484
http://forum-archive.magix.info/showmes ... eid=899171
