I had a problem playing music tracks from windows media player or vlc via voicemeeter banana VAIO media player channel into Zoom which is on B1.
Microphone audio from input 1 was fine.
If I listened to the music using headphones on A1 or recorded the music on voicemeeter monitoring either A1 or B1 it was also fine. But the recording on zoom was distorted - only the music, not the mic.
In zoom settings, audio, advanced, there is an option to "enable original sound" in meeting. Also there are 3 options under a heading of audio processing.
I was only able to disable the first two but when I recorded the following meeting I did not click on the option to "Turn off original sound" and the recording was perfect.
I don't know whether anything on the voicemeeter side caused the audio processing to distort the sound but using original sound stopped it from doing so.
I am posting this in case it can help someone else.
Voicemeeter problem with Zoom
Re: Voicemeeter problem with Zoom
cannot help without screenshot showing your entire audio config/paths.
but you may find some recommendation there:
viewtopic.php?f=6&t=451
spinnekop@gmail.com
Hi Vincent
Sorry if I am not clear. The problem turned out to be with Zoom, not voicemeeter. Under audio->advanced setting. Disable audio 'enhancements'
