Voicemeeter Potato "SEL" button not saving settings.....
Posted: Mon May 25, 2020 12:05 pm
Hi all,
i've recently switched to using Potato because of all the extra outputs. In the Master Section, the SEL button proves really handy if i want to change the gain on 2 outputs but leave the third untouched. The third output is an HDMI to a capture card on a second pc and that volume needs to remain "locked" while the other outputs can go up or down in gain.
However, it seems this value (SEL button on or off) is not saved in the settings so is removed after each reboot. Is there a way to make it "saveable" in the settings or by using a macro or something??
Thanks!!
Thanks!!
