I have a specific problem and want to disable the triggers on and off, just dont know how to do it via macro commands if there is a way...
... to disable "Triggers" via macro command
Is it currently possible to enable/disable a "trigger" of a macro button via macro command? precisely one of this.
Re: ... to disable "Triggers" via macro command
ok, i note it for next update.
