Monitor a different output bus (Potato)
Posted: Sun Jun 28, 2020 1:46 am
Is there a way to just choose an output bus like A3 or B1 and just monitor it?
The reason is for example. If I'm streaming and I have voice chat, my mic, and music playing, I can adjust what I hear through my headphones (BUS A2-Headphones) but I can't check what my mix sounds like for the stream (BUS A5-Virtual Cable). I can use the SEL button to change the levels for A2 and A5 separately, but I can't hear what the other mix sounds like. I could add the virtual cable to one of the input strips and listen to that, but it would be nicer if I could monitor the mix for another BUS easily. It also isn't practical if you start adding different mixes, for example if A4 was a mix sent to my voice chat, A5 to the stream, and A2 to my headphones.
I only learned how to use the SEL to adjust the mix for that output recently, so there may already be a way to do it, but if not, what I would like to see is another button under SEL like SOLO that lets me just hear that BUS over a selected monitoring device.
