Separate track output?
Posted: Mon Jul 13, 2020 5:16 am
by Shuik1
I'm not very tech savvy so this might be a stupid question, but I use the tape recorder function on Voicemeeter to record multiple microphones and I was wondering if there was a way to make each microphone's output to be recorded to a seperate audio file?
Re: Separate track output?
Posted: Thu Jul 16, 2020 7:29 pm
by zBeeble
For some reason that I don't understand, the option to record more tracks is enabled when you change to post-fader outputs (in the options). Now... it seems you'll have to direct your microphones to the extra channels to make this all happen ... and this is not really how things are meant to happen.
That-said, with potato and virtual cables, you could connect the outputs A1 thru A5 to audacity and have either 5 or 10 channel recording.
Posted: Fri Jul 17, 2020 5:20 am
by Shuik1
zBeeble wrote:For some reason that I don't understand, the option to record more tracks is enabled when you change to post-fader outputs (in the options). Now... it seems you'll have to direct your microphones to the extra channels to make this all happen ... and this is not really how things are meant to happen.
How do I do this?
