				VBAN Receptor Not Working
				Posted: Thu Jul 16, 2020 7:17 pm
				by thusup
				The VBAN Receptor app shows green for RCV but doesn't output any audio or show anything in the visualizer. This is a new issue with no change in configuration.
				Re: VBAN Receptor Not Working
				Posted: Mon Jul 20, 2020 10:31 am
				ok, but which version, for what plateform ?
did you make a ping test to check IP-Address are ok ?
				Posted: Tue Jul 28, 2020 12:54 pm
				by thusup
				The sender's IP address had changed, so that needed changed in the receptor as well. I don't know why it registered incoming data in the RCV indicator when it wasn't actually connected to a stream.
