Using Zoom G3 ASIO as main out cause Voicemeeter to freeze
Posted: Sat Aug 01, 2020 10:28 pm
Hi! I'm having trouble using Voicemeeter with my main audio interface (Zoom G3) ASIO driver.
After audio engine is started with this device as the main out, application freezes on almost any action, including closing the application itself.
I've tried to follow the advice from viewtopic.php?f=6&t=894 and set the buffer to be 256..1024, but that didn't help.
This same ASIO driver works well in other applications. And I can use Voicemeteer with both other Zoom G3 drivers and ASIO drivers for other devices (including Zoom H1). Unfortunately those other options don't work for me, because I planned to use Voicemeeter routing capabilities to play guitar with VST effects along with other media, streamed through internal audio.
Are there any logs to check what might go wrong with this particular driver?
BR,
Kirill
BR,
Kirill
