Page 1 of 2
VoiceMeeter licence
Posted: Tue Aug 04, 2020 11:25 am
by wwwkennyseqcom
Hello ... I have a big one with your VoiceMeeter Banana program. I have paid my license and at the same time the program throws me a message every month that I have to reactivate the license! Is it like a license for only a month? Or what is the problem ?! It's quite frustrating when I always have to adjust all the sound settings in my OBS over and over again !!!
Thank you for answer
Re: VoiceMeeter licence
Posted: Tue Aug 04, 2020 2:33 pm
Voicemeeter Banana displays an About Box to invite you to donate...
but if you already did it, just click on “I Already made a donation” on bottom left of the dialog box.
Posted: Wed Aug 05, 2020 7:29 pm
by wwwkennyseqcom
Vincent Burel wrote:Voicemeeter Banana displays an About Box to invite you to donate...
Can you please indicate the place I should click on if I have already sent DONATE? thank you because I don't see anything in the lower left corner ?!
Posted: Wed Aug 05, 2020 10:03 pm
by hotmitts
I was wondering about the License too
I have Voicemeter (plain old vanilla flavour) and donated -should i have got a code ? maybe I did and didn't check all my mails ? Or don't I need one ?
I can remove the donation screen like you say, just wondering if it transfers, if have to re-activate on a future computer.
Thanks
Posted: Thu Aug 06, 2020 9:15 am
by TestXpress
Hi wwwkennyseqcom,
Voicemeeter Banana (that you mentioned) and Voicemeeter Potato (that your screenshot shows) are different products. So, what did you donate for? I would expect Potato to decline license codes intended for Banana, as Potato brings more functionality.
Posted: Thu Aug 06, 2020 11:33 am
by wwwkennyseqcom
TestXpress wrote:Hi wwwkennyseqcom,
You can find my payment in the attachment and thank you very much for finding someone who is dealing with my problem and trying to solve it.
Posted: Thu Aug 06, 2020 4:38 pm
by TestXpress
Okay, thanks for clarification, that seems to be fine. So, activation itself is successful (big green "ACTIVATED" on the dialog) but after a month it suddenly resets the status? Normally it should just stay in status "ACTIVATED"...
Posted: Thu Aug 06, 2020 6:12 pm
For this kind of question, you may contact us by the webshop contact form:
https://shop.vb-audio.com/en/contact-us
Posted: Fri Aug 07, 2020 12:24 pm
by wwwkennyseqcom
TestXpress wrote:Okay, thanks for clarification, that seems to be fine. So, activation itself is successful (big green "ACTIVATED" on the dialog) but after a month it suddenly resets the status? Normally it should just stay in status "ACTIVATED"...
Yes, I have to set everything over and over every month: /
Posted: Fri Aug 07, 2020 12:35 pm
by wwwkennyseqcom
Thank you for the link on which I will hopefully finally be able to solve my problem.
I have already filled in the form and sent it so we will see what it will be like in the end.
