Voicemeeter Banana output to VoIP via Virtual Cable gives poor audio
Posted: Sat Aug 22, 2020 9:02 pm
I’m trying to use Voicemeeter Banana (latest version) and it works great in all but one respect – one output gives audio so choppy and bad that it’s unusable.
I’m recording a podcast, and I usually have a guest on Skype, (or some other VoIP solution, or a softphone) and I want to play audio clips into the show and have the guest react to them.
I find it important that both myself and the guest doesn’t hear their own voice feeding back to them as this is distracting. I have a basic audio player that uses Voicemeeter Aux as its output, and set Skype to use Voicemeeter Vaio as its audio output. The guest always uses earphones to prevent feedback.
The cassette recorder is set to record B1, and all three inputs record with perfect quality on separate tracks.
I have my local sound card set under A1 and listen through earphones, and I hear the guest and my audio player perfectly.
I have my microphone and Voicemeeter Aux (the audio player) live for A2 and send this audio to WMD Cable Input, in the hope of sending my voice and the audio clips to Skype, for the guest to hear and converse with me.
Unfortunately, A2 is giving very poor-quality sound, to the point that the guest can’t understand what is being said. I have tested this with multiple clients (Skype, web-based VoIP, softphone) and the problem is always the same. The problem is also the same both for my voice (microphone input) and audio from the audio player.
I have a quite powerful computer so I don’t think that’s the issue.
I would be very grateful if anyone can suggest a way to make this audio (via virtual cable or otherwise) more usable. Many thanks for all your help.
