First of all thank you to Vincent for putting out such an amazing program to the world!
Recently, I notice OB Studio has implemented RNNoise - a great noise suppression (free) filter. Its a GITHUB open source free code.
Its a really solid noise suppression software and is better than the list filter OBS studio had (which caused bad audio artifacts).
I was wondering if this is something you would think of adding into Voicemeter banana, similar to how the gate and compression is added in?
Thanks again!
RNNoise for Voicemeter (added to OBS studio V26 beta)
Re: RNNoise for Voicemeter (added to OBS studio V26 beta)
no, for the moment, we have no plan to include noise-remover algorithm in Voicemeeter... but i note your question as a request.
https://github.com/werman/noise-suppression-for-voice May be of interest, this is a VST plugin implementation of RNNoise.
