Virtual cable input is entirely lost?
getter345
Post by getter345 »
My usecase is trying to get OBS (which I use to capture desktop audio) -> Discord as an audio source without any processing needed.
However it seems that while OBS does correctly capture the audio to the input of the cable, the output doesn't seem to show anything at all and all the data appears in the "push loss" column.
The audio control panel also shows input receiving a signal while the output not mirroring it:
I'm on win10; thanks for any assistance in advance!
Re: Virtual cable input is entirely lost?
yes, this is normal because you have apprently not connected any application on the cable output, so all buffers sent to the cable input are lost.
(this statistics are for expert and troubleshoot only).
getter345
Post by getter345 »
Ah, thanks, figured out the problem - I think I had unchecked "allow apps to use microphone" at some point which interfered with the cable's ability to broadcast to applications.
