Rapid Overrun and Underrun alternating
HoustonGuyNW
Post by HoustonGuyNW »
I have Vban Receptor on 2 Android Samsung J3 phones. I get over-run and under-run rapidly cycling errors back and forth. Even when sitting next to the router. Set to OPTIMAL or FAST both options do the same while beside the router. When I turn off wifi then reboot the phone it gets better for a while after restarting the wifi next to the router.
Are these phone known to have issues with VBan Receptor?
Does that indicate a more underlying issue with the network? (What type of problems cause that sort of issue?)
An iPhone 7 and an iPad iOS14 both work fine.
Thanks in advance.
Re: Rapid Overrun and Underrun alternating
we need to update Android version anyway.
