POTATO (ASIO 128)
AUX is default communication
I have 8 channel tape.
I have B3 set as tape.
I have foobar output to VAIO3, then B3, I have stereo w/histogram, composite w/o histogram. (hmm) No 8 channel histogram is strange works on Banana.
So to test other channels.
While foobar is still set output with VAIO3 I sel out (A1) active to VAIO > Sound outputs (what?!) ... I have stereo w/histogram but no composite... there ought to be no output on A1. If I leave A1 active on VAIO3 while VAIO A1 is active and raise volume I get wonkier kaleidoscope music.
Then, I put foobar out (A1) active to VAIO AUX > A1 , No sound output... that is fine because it is right. There should be no output.
Why is VAIO3/Bus3 crossing over to VAIO?
BANANA
Works fine. All 8 channels all interfaces. No channels crossing over to channels its not suppose to. I moved to POTATOs for more application control.
