Hello
I am new to this forum. And just started using Voice-meter on my regular Laptop. But what I plan to do is on my Friend's PC.
PC 3.5mm Headphone out(Dolby Atmos For Headphone) > THX-AAA-788
PC USB-1(Unprocessed) > Sennheiser GSX 1200 Pro > THX-AAA-788
PC USB-2(Unprocessed) > THX-AAA-788
So is there a way to set USB output to be Unprocessed digital output what codec should I be using.
Now coming to Main topic Dolby Atmos For Headphones. If I set headphone out from PC to Dolby Atmos should I using WDM or MME. Which of these will be direct Unprocessed by Voicemeter. I tried it on my Laptop but it seems MME is being processed by Voicemeter as the Audio output I get using Headphones as Default it sounds different than what it sounds when I set Voicemeter Input as Default and use MME-Headphones but gives 8ch output. If I use WDM it sounds similar though have not tested surround yet but it only shows to be 2ch. Why is that. Am I missing something.
Voicemeter Banana Output Dolby Atmos For Headphones
KING DRANZER
