API equivelent of "-remove device selection-"
simmondp
Post by simmondp »
In Potato when selecting the dropdown, there is the option to of "-remove device selection-" - a null selection.
However in the API there is only the option to set a device.
  • Strip.device.wdm
  • Strip.device.ks
  • Strip.device.mme
  • Strip.device.asio
Anyone know how to un-set the selection using the API??
Re: API equivelent of "-remove device selection-"
set a device with an empty name maybe : ""
simmondp
Post by simmondp »
Pleased to report that
Strip.device.wdm = ""
Works!
Thanks
