				Compressor or VST effects with Voicemeeter
				Posted: Fri Mar 05, 2021 1:35 am
				by rodak
				Is the Compressor feature only available with Potato?  The basic Voicemeeter more than meets my needs, but I'd really like to have a compressor.  Or is it possible to use a VST plugin with Voicemeeter or Banana (which is still more features than I need, but...)
				Re: Compressor or VST effects with Voicemeeter
				Posted: Fri Mar 05, 2021 3:37 pm
				audibility knob in Voicemeeter Standard is implementing Compression/Gate effect if you can find a good settings, maybe around the value 2.0.
Voicemeeter Banana offer separate knobs, one for comrpression , one for gate.
				Posted: Sat Mar 06, 2021 3:48 am
				by rodak
				Great, thanks!  I'll give it a try.
				Posted: Sat Mar 06, 2021 3:57 am
				by rodak
				Ah, so Audibility only works on the two hardware input channels?  Rats.  I was looking for something that would compress the Virtual input.  What I'm trying to do is compensate for the sometimes large volume levels of different speakers on Zoom/Skype/Teams calls.  I often find myself continually riding the volume to hear quiet speakers or keep louder speakers from breaking my eardrums.
				Posted: Sun Jul 04, 2021 11:46 pm
				by MartyATS
				Indeed, I'm trying to watch a youtube tutorial and the presenter screwed up their audio settings. The first word of every paragraph is stupid distorted loud, and then it dies down to barely audible.
A compressor on the virtual inputs would be super helpful
