I accidentally moved the sound source (red dot) in the 5.1 Pan Pot of Voicemeeter VAIO Virtual Input.
How can I position it again at the exact center, so there is no Pan at all ?
Or is there a way to completely disable the Pan Pot, so this doesn't happen again ?
Thanks !
Voicemeeter Banana - 5.1 Pan Pot
Re: Voicemeeter Banana - 5.1 Pan Pot
Hi. You can double-click inside the panel to restore the square box to the default position.
VoiceMeeter Menu includes a Lock Graphical User Interface option but it is not restricted to panels (It locks everything).
Since you are using Voicemeeter Banana this doesn't apply directly to your scenario: the March 2021 release of VoiceMeeter Potato will include the option to right click in the application list of Virtual Inputs which with will toggle the visualization of Equalizer and Pan.
Hope this helps.
Hope this helps.
Thanks ! That helped perfectly. I didn't notice that double-clicking centered the red dot. I had only tried right-clicking.
Now I have locked the GUI and all is well.
