Hey guys,
just a short question.
Is there any technical difference between the normal version and the additionally installed "x64" version in case of stability?
I just ask because normally...why not... I would use the x64 version. But after a new installation voicemeeter still runs the x32 version. I could change the autostart but maybe there is a reason why voicemeeter just like to start in x32.
This is a little bit irritating. =)
Thanks.
Voicemeeter x32 or x64
Re: Voicemeeter x32 or x64
Latest versions of VM use the x64 version when you run x64 Windows. I've been using it exclusively since it was an unannounced feature and never seen a single issue with it. Go for it ![Smile :)](./images/smilies/icon_e_smile.gif)
