VMRAPI gives different level value than VM alone?
K4M1s
Post by K4M1s »
Hello, I'm trying to create simple android app to control Voicemeeter Banana on my PC. I'm using websockets to communicate between my app and Java app on my pc. I've used this wrapper for VMRAPI: https://github.com/mattco98/Voicemeeter-JNA-Interface
The problem i'm facing with is voicemeeter shows different value for level than my app reads from API.
Example:
I'm using this formula to convert value that api gives me:
lLevel =  Math.max(-80, Math.min(12, 10 * Math.log10(volumeLeft)));
rLevel =  Math.max(-80, Math.min(12, 10 * Math.log10(volumeRight)));
I'm reading data from API like that:
volumeLeft = Voicemeeter.getLevel(3, (ID * 8));
volumeRight = Voicemeeter.getLevel(3, (ID * 8) + 1);
First parameter is type, I'm using 3 because this is output bus I guess.
Am I supposed to use different formula or type for reading from API?
EDIT: The difference between value that shows Voicemeeter and logged out from my app is not constant.
Re: VMRAPI gives different level value than VM alone?
dB = 20x LOG10 (level)
K4M1s
Post by K4M1s »
That seems right, why the wiki says 10log10 then? (I was checking this https://en.wikipedia.org/wiki/Decibel, formula under the table on the right)
suerly because they are talking about power (watt) not signal level.
and between signal and power there is a square somewhere...
https://vb-audio.pagesperso-orange.fr/f ... ecibel.htm
