Current VBAN stack design allows to expect 50ms latency max (< 2 Frames) on a real time stream.
To optimize latency for VBAN stream, you may
1- first use a buffering around 512 samples for the output A1 (= master Voicemeeter stream) - below 256 samples buffer size, this has no impact on VBAN since the current implementation of the VBAN stack is searching to build 256 sample paquet size anyway.
2- On the receptor side, you may set the Network Quality parameter to FAST or OPTIMAL (search the best value for a stable stream).
3- Check that outgoing VBAN streams are set in OPTIMAL Network Quality parameter (there is usually no reason to change this parameter).
Optimize VBAN Latency (< 2 Frames)
