After trying different approaches for a few days, the one that got me closest to what I want was using VoiceMeeter with an outgoing VBAN stream on my desktop to a VBAN receptor using https://github.com/quiniouben/vban/.
With this, when I plug a speaker to my Raspberry Pi I can successfully hear the sound from my desktop.
The problem I'm facing right now is that the strip only reacts to sound either capturing audio direct from an USB mic or when VLC is playing audio. In other words, when I run the following script:
import pyaudio
p = pyaudio.PyAudio()
stream = p.open(format=pyaudio.paInt16,
channels=1,
rate=48000,
input=True,
frames_per_buffer=960)Code: Select all
$ sudo python3 ledstrip/firmware/app.py
ALSA lib confmisc.c:767:(parse_card) cannot find card '1'
ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5047:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM sysdefault
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm_hw.c:1822:(_snd_pcm_hw_open) Invalid value for card
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
ALSA lib pcm_a52.c:823:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM iec958:{AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2 CARD 1}
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM dmix
Traceback (most recent call last):
File "ledstrip/firmware/app.py", line 471, in <module>
start_stream(microphone_update)
File "ledstrip/firmware/app.py", line 379, in start_stream
File "/usr/local/lib/python3.7/dist-packages/pyaudio.py", line 750, in open
stream = Stream(self, *args, **kwargs)
File "/usr/local/lib/python3.7/dist-packages/pyaudio.py", line 441, in __init__
self._stream = pa.open(**arguments)
OSError: [Errno -9996] Invalid input device (no default output device)
Relevant info:
$ arecord -L
null
Discard all samples (playback) or generate zero samples (capture)
jack
JACK Audio Connection Kit
pulse
PulseAudio Sound Server
default
Playback/recording through the PulseAudio sound server
$ python3 -m sounddevice
0 pulse, ALSA (32 in, 32 out)
* 1 default, ALSA (32 in, 32 out)
