Problem with voicemeeter banana
Luca4389
Post by Luca4389 »
Hello guys, here my problem, i have downloaded voicemeeter banana because i want to stream with streamlab.
The installation and setting go pretty well, i have setted for my default sound output the voicemeeter inpunt, then i manually selected the voicemeeter aux inpunt for the program i want to have the audio on streamlab and it worked fine, but i noticed that when i close the game/program setted on voicemeeter aux input the audio will exit on the normal input.
I don't know if my description of the problem is clear
Re: Problem with voicemeeter banana
Hi. Just to clarify: this issue is not specific to Voicemeeter; it will occur using other audio devices as well: some programs (especially games) will use Windows default output device despite your preferences. Are you using App volume and device preferences to select VoiceMeeter Aux Input for the game/program? Some users try to use alternatives as EarTrumpet to redirect audio to a specific application.
Please let us know if you find alternative solutions.
Luca4389
Post by Luca4389 »
Andres wrote: Sun Jun 06, 2021 8:22 pm Hi. Just to clarify: this issue is not specific to Voicemeeter; it will occur using other audio devices as well: some programs (especially games) will use Windows default output device despite your preferences. Are you using App volume and device preferences to select VoiceMeeter Aux Input for the game/program? Some users try to use alternatives as EarTrumpet to redirect audio to a specific application.
if you mean this
yes, i'm using app volume and device preference, for example i used league of legends client, but i have the same problem with hearthstone too
the language in the pc is not english becuase i'm italian and the system is in my mother language
Luca4389
Post by Luca4389 »
after installing eartrumpet seems like the problem is fixed partialy, because with league of legends it work fine, but with hearthstone it keep switch to normal input from aux input even if in App volume and device preference is set on aux input
