error but i felt its working
oxed
Post by oxed »
hello, i keep getting error when i restart my pc however if i just ignore and relunch the voice meter everything work. is there away to fix those below without reinstall?
HECKING VB-Audio Virtual Cable (version 01000305)
*ERROR MME Input - Bad Pin Icon: %windir%\system32\mmres.dll,-3012
*ERROR MME Input - Found same Icon used by: CABLE Output (VB-Audio Cable A)
*ERROR MME Output - Bad Pin Name: Speakers (VB-Audio Virtual Cabl
*ERROR MME Output - Bad Pin Icon: %windir%\system32\mmres.dll,-3010
*ERROR WDM Input - Bad Pin Icon: %windir%\system32\mmres.dll,-3012
*ERROR WDM Input - Found same Icon used by: CABLE Output (VB-Audio Cable A)
*ERROR WDM Output - Bad Pin Name: Speakers (VB-Audio Virtual Cable)
*ERROR WDM Output - Bad Pin Icon: %windir%\system32\mmres.dll,-3010
*ERROR TOTAL FOUND: 8
CHECKING VB-Audio Cable A (version 01000305)
*ERROR MME Input - Bad Pin Name: CABLE Output (VB-Audio Cable A)
*ERROR MME Input - Bad Pin Icon: C:\Program Files\VB\CABLE\pin_out.ico
*ERROR MME Output - Bad Pin Name: Speakers (VB-Audio Cable A)
*ERROR WDM Input - Bad Pin Name: CABLE Output (VB-Audio Cable A)
*ERROR WDM Input - Bad Pin Icon: C:\Program Files\VB\CABLE\pin_out.ico
*ERROR WDM Output - Bad Pin Name: Speakers (VB-Audio Cable A)
CHECKING VB-Audio Cable B (version 01000305)
*ERROR MME Output - Bad Pin Name: Speakers (VB-Audio Cable B)
*ERROR WDM Output - Bad Pin Name: Speakers (VB-Audio Cable B)
*ERROR TOTAL FOUND: 6
CHECKING VB-Audio VoiceMeeter VAIO3 : Not Installed
TEST DATE: 2021/06/12 - 08:46:06 (Checker Version 1.0.7.7)
Operating System: WIN 10 64Bits Build: 19042
CONCLUSION: 22 error detected (You may consider re-installing audio drivers)
Re: error but i felt its working
the VBDeviceChecker hasd been done to detect bad driver installation (mainly due to WIN10 update).
this is made by detecting inconsistency in the different information we could gather in different audio device lists and registry database.
As suggested, if you think it's working anyway, just ignore this warning. But if you get any problem with audio or device routing / selection, you may consider re-installing this audio driver properly.
Please refer to this topic.
