hi guys im using B3 as a mic to discord and hardware input 1 as input for my actual mic
and when i press a1 on the mic strip to hear myself it is clear.
but my friend hear my very static.
some pictures here https://workupload.com/archive/8mgnhSxf
AUDIO which goes to discord is static
xcasxcursex
Re: AUDIO which goes to discord is static
I'm sorry but this is a long-standing problem with discord. You will notice that if you attach an audio recording application to the same output from voicemeeter, the audio recorded is perfectly clear. The problem occurs internally to discord, and discord have known about this problem for years and show no sign of ever fixing it.
ok, but there is different fix to try:
for example the 48kHz seems to be better supported by Discord.
In system settings in voicemeeter, you can change the “preferred main sample” rate to 48000 Hz.
then the main audio stream and VAIO Base Sample rate in Voicemeeter will be 48kHz.
if it still does not work, you may set the virtual output audio format in 48kHZ by the windows audio device control panel
(for in Recording Device List and select the one used by Dsicord,go in properties dialog box Advanced Tab to set the default audio format).
Other fix are based on the audiodg.exe priority/multicore settings
Video Tutorial: https://youtu.be/71HrZfR_Fro
other fix with PowerShell:
https://hackmd.io/@JulienGuillaud/B17OP7uCt
