I often get to go through this sequence to access the device settings in Windows 10 to change the level of a device:
Sound Settings > Sound Control Panel > Playback/Recording > [device] > Properties
Would you mind explaining why? Generally, you'd set it appropriately (usually this means leave it at 100%) and adjust volume in voicemeeter. I can give you a better answer if I understand the use caseI often get to go through this sequence
