VMR OSD (Over Screen Display)
VMR OSD is an application using Voicemeeter Remote API to display the current moving Gain slider in the right-bottom of your display screen.
(VMR OSD is Also provided in the Voicemeeter Remote API SDK, as source code).
you can download the compiled application directly there: http://download.vb-audio.com/Download_C ... sd_app.zip
just RUN it, it will be placed in the system tray and will popup when changing any input or output Slider Gain (if Voicemeeter GUI is not visible of course).
