Random single crackle
Posted: Fri Jul 23, 2021 11:41 am
Specs:
AMD Ryzen 9 3950X
32Gb RAM 3600 CL18
Windows 10 Pro x64 21H1
Behringer U-PHORIA UMC404HD (Revision v1.12) (4.59/5.0/5.12)
Voicemeeter Potato x64 3.0.1.8
Everything set to 24bit 48kHz
Problem:
Random single crackle. Can be noticed once a minute or hours (obviously I not notice them all).
Appear only when some sound already playing.
Appear with different sound sources Firefox, MPC-HC, etc.
How it looks on record via Voicemeeter recording tool:
Voicemeeter A1 → ASIO Behringer — Problem
Voicemeeter A1 → WDM Behringer — Problem
No Voicemeeter, Default windows output is Behringer — No problem
Checked things:
ASIO buffer 32-2048, not affect on a problem.
Behringer driver version not affect on problem (4.59/5.0/5.12)
A2 on/off not aftect on problem.
Patch insert on/off (to LightHost with VST) not affect on problem.
Voicemeeter x64 or x32 not affect on problem.
Reinstall all audio, step by step, as in forum instruction. No affect.
audiodg.exe priority and/or core affinity, not affect on problem.
All apps use default output (VAIO) or Voicemeeter AUX/VAIO3.
I still not tried reinstall Windows, but it will be last step.
Sooo, is anyone have an idea, what else I can do with it?
AMD Ryzen 9 3950X
32Gb RAM 3600 CL18
Problem:
Checked things:
