Voicemeeter stops working with my Soundblaster X7 Audio
Posted: Sat Jul 24, 2021 8:44 pm
Hello wanted to see about some advice on what I may be missing with the setup of this to make it stable. I've been having some major issues with my Soundblaster X7 ever since installing this. Uninstalling both this and my X7 drivers and reinstalling hasn't helped.
The issue happens with both WDM and ASIO though presents slightly differently with each.
With WDM the audio output will continue to work fine but the audio input will turn red after a period of time and stop working. This can be fixed by selecting the audio input again or by Restarting Audio Engine. Automatically restart engine does not work.
With ASIO the audio output works okay initially. Audio input often doesn't work though occasionally it does work and once set seems to work until system restart. For both the audio will cut out and stop working after a period of time. Selecting a different audio input and switching back or restarting Audio Engine fixes it. Automatic restart engine makes the sound fuzz out for about 2 seconds, go dead for another 2-3 and then start back up.
Windows default audio device is set to one of the voicemeter inputs and all of my audio devices are set to 24 bit 48000 with all audio inputs being set to 2 channel and the audio output voicemeter is using being set to 5 channel. Buffer size for ASIO defaults to 2400 though that seems to cause issues for the virtual inputs and has really long latency so I swapped it to 960 via the driver config. Issue happens at both settings as well as 480.
I've also tried a firmware update in case that was the issue. Prior to the firmware update there were 8 ASIO inputs with 1/2 being the mic and they worked 99% of the time. Following the firmware update there are 2 ASIO inputs and they work maybe 10% of the time. The inputs instead seem to be getting tied to the line-in inputs
Things seem super borked in general with this setup and have been fighting with it for a couple months now. Wondering if anyone has any feedback or insight into what I might be doing wrong that I didn't think of.
Other config details available on request, not sure what you guys might need.
P.S. does anyone know of a tool to check ASIO input config and figure out why my inputs only occasionally work on current firmware?
