Ever since I installed the latest version of Voicemeeter Banana, whenever it opens I get a strange screen to go with it (see picture).
Looking at the logfile makes me none the wiser.
Any idea what could be causing this?
I never had this with previous versions.
Thanks in advance.
Strange popup on opening Banana
Re: Strange popup on opening Banana
Hi. Since March 2021 update Voicemeeter will check for any virtual audio device/driver issue in your system at startup. It uses a small utility VB-Audio Devices Checker that you can run using the Menu - Check Driver Installation option. If the utility finds something out of the normal (like virtual audio device has changed name, icon or is disabled) it will show the warning message attached to your message.
Most of the times you can fix the issues present by uninstalling Voicemeeter, restarting Windows and then installing it again and restarting Windows one last time.
If you have some time you can try that. Or if you prefer you can ask for help in VB-Audio Discord server where the community can help you with the issue.
Hope this helps. Let us know if you need further help.
