New update broke macro buttons
Posted: Sun Aug 15, 2021 5:18 pm
New update to the macro buttons broke my stream deck (like none of the macros I made before work cuz of the ID's disappeared) & the HID device selection thing doesn't work for some reason? Like is there something you need to do beforehand? I just set the streamdeck to an empty profile, select one or two (to test) of my macros put them to HID: Stream deck, select the buttons (which is weird as my PC recognizes the button ID's from 0 to 14 instead of 1 to 15 and there's no 0 in macro buttons selection thingu). So. After doing the selecting. Nothing works. Atm just running the macro buttons panel on another monitor, but that's just bullshit & annoying.
A) Is there a fix?
B) Is there a tutorial how to do it correctly if I'm doing it wrong?
C) Is there a way to downgrade? Like is there downloadable version of macro buttons before this update (didn't backup myself as thought this update just works).
A) Is there a fix?
