I'm currently using A-B cable and it works great for me. Wanted to add in the C-D cable to add an additional SDR for UT2 and Trunking Recorder, but when I added it all cables stopped working and no audio was being sent.
Any trouble shooting suggestions?
VB-Cable Install Issue
Re: VB-Cable Install Issue
Hi. You could start checking VB-Audio Virtual Cable installation using the utility mentioned in this post: https://forum.vb-audio.com/viewtopic.php?f=7&t=688
You can also try to get help using VB-Audio Discord Server. You will find the link in the VB-Audio Support page: https://vb-audio.com/Services/support.htm
Hope this helps.
Hope this helps.
