Dante Virtual Soundcard WDM: Failed to Open Main Output Device
polyh3dron
Post by polyh3dron »
For some reason, I am unable to set Dante Virtual Soundcard as a WDM output in Voicemeeter Banana, I get the "Failed to Open Main Output Device" error. Using MME works, but I am hoping to use WDM for its far lower latency capabilities. I've included a shot of the error window below. Is Dante Virtual Soundcard's WDM driver just not compatible with Voicemeeter?
Re: Dante Virtual Soundcard WDM: Failed to Open Main Output Device
check it is not used by another app or
maybe should use the ASIO driver instead..
pmueller
Post by pmueller »
Hi
Same on my side. Voicemeeter Potato can't open DVS (Version 4.2.0.2) WDM output devices. I read in the Voicemeeter documentation, that voicemeeter tries to open the devices in exclusive mode. So it looks like another app is using the device already but I have no other sound application started.
ASIO is not an option because my primary device used by Voicemeeter is already an ASIO device.
How can I check which other application is using a device? Or did you find another solution for that?
Thank you!
Best regards,
Patrick
this is maybe a question for Dante company as well...
however, we will offer a new application soon, able to manage several ASIO driver so, this could solve your problem...
