VoiceMeeter (All) bugs: EQ settings not saved (A/B)
Posted: Sun Sep 05, 2021 5:09 am
Hi there,
Thank you for your continued efforts to keep VoiceMeeter running and improving!
Bug description:
Specifically after pasting a preset (usually for the "B" preset) for EQ settings, and you close the settings, it is not saved, and sometimes (at least in older versions) overwrites preset "A" (!)
So using presets is sometimes a scary experience
So for a long time I have avoided them like the plague, until I found a workaround.
The first bug may be related to VoiceMeeter not flagging "preset was changed" after pasting (see below: Workaround 2, step 3).
The second bug may be related to either how VoiceMeeter saves or loads the B preset to file (see below: Workaround 2, step 6).
Bug reproduction:
1) Open EQ settings for an output channel
2) Change some settings (like decibel EQ sliders) (to notice a change)
3) Click copy (preset) -- "Ch.Copy"
4) Open EQ settings for a *different* output channel
5) Click preset B
6) Click paste (preset) -- "Paste"
7) Close settings
8) Open the same output channel EQ settings again (step 4)
You will see that either the B preset was not saved, or it has overwritten preset A (older version).
Workaround 1 (tested and works
1) Buy additional sound card
(i actually did
Workaround 2 (doesn't actually work!):
1) After pasting a copied preset, change one of the sliders in the EQ
2) Close the settings
3) Opening it again will show that the preset was saved (in memory!) properly.
... BUT
4) Close VoiceMeeter
5) Open VoiceMeeter
6) Open EQ settings and all B presets are GONE! (for all audio channels)
I hope you can fix this!
Thank you <3
Bug description:
Bug reproduction:
5) Click preset B
7) Close settings
... BUT
5) Open VoiceMeeter
Thank you <3
