Could anyone tell me how I can separate the 1/2 & 3/4 inputs in Voicemeeter banana from the Behringer UMC404HD? I have read the answers to similar questions but was struggling to follow the answer.
Thank you,
Joe
Separate inputs 1/2 & 3/4 on the Behringer UMC404HD
Re: Separate inputs 1/2 & 3/4 on the Behringer UMC404HD
Hi. The Behringer UMC404HD includes an ASIO driver which you can use with Voicemeeter. If the driver is correctly installed in your system you will find an ASIO option at the end of the selection list for Hardware Out A1. After selecting the ASIO option at A1 you can use the PATCH ASIO Inputs to Strips section of the Voicemeeter System Settings / Options... window to patch any of the 4 inputs in your interface to the Hardware Inputs in Voicemeeter Banana.
You can read this Quick Guide https://voicemeeter.com/setup-a-mic-wit ... interface/ and after that you can take a look at this video: https://youtu.be/35N8hkOy8h4
Hope this helps. Thank you for contacting us.
Works great, thank you!
