desktop application is set to Voicemeeter AUX and was working fine. Now with no change to settings it is coming from Voicemeeter VAIO
[/attachment]
Audio Source Switched Input From Aux to VAIO
DG_Trade
- Snag_55c824.png (90.12 KiB) Viewed 9097 times
Re: Audio Source Switched Input From Aux to VAIO
Hi. Thank you for contacting us. Please take this as general comments since there is not a proper fix to this on the Voicemeeter side.
- Check if the application provides some kind of audio settings that allows you to select an output device directly from within the application
- Some applications will not use the preferred device at startup but re-selecting it at App volume and device preferences will send the audio to the correct device. One example is Google Chrome or Microsoft Edge both of which will use the default device instead of the preferred device the first time you play a YouTube video after starting the application; the second video will playback through the preferred one
- This behavior is not related to selecting VoiceMeeter Aux Input as your preferred device; you can also set it to for example your speakers but the audio should appear on the default device
