VBan no longer runs on iPad
Posted: Sun Oct 03, 2021 2:13 pm
by HoustonGuyNW
I have an iPad that has been working well. I have noticed that now when I try to run Vban on it the logo screen comes up and then disappears. It no longer works on that iPad. I tried deleting it and reinstalling. I also tried installing vban lite just to see, it doesn't work either.
Is there a setting that changed I should check? Please help.
Re: VBan no longer runs on iPad
Posted: Mon Oct 04, 2021 9:18 am
no, could you give your ipad and OS version ?
Posted: Mon Oct 04, 2021 6:07 pm
by HoustonGuyNW
The OS is iOS 9.3.5. The iPad model is MC979LLA/A
Posted: Fri Oct 08, 2021 10:16 am
ok, we are going to check this... another update is planned next week.
Posted: Mon Oct 18, 2021 8:41 pm
by HoustonGuyNW
I decided to completely reset the iPad to factory settings and reinstalled. Seems to work now.
Thanks
