Hello
I am planning a special project - VB-cable is playing a key role, but I am still unsure about configuration.
Main goal: it needs to be bit perfect, work with ASIO and exclude all „Windows 10 sound processing interference“
Project description:
HighEnd analog gear (phono preamp & studio tape machine) are digitized to 192kHz/24bit using a studio quality A/D converter (ASIO, USB) on a Windows 10 mini computer.
Only THIS signal (A/D inputs 1&2 or eventually inputs 1,2,3&4 for both stereo sources) should be taken and sent to a software called „SWYH-RS“, („Stream what you hear“), which embeds the signal into a stereo UPnP stream, that can be picked up by DNLA-streaming clients via LAN.
This process should be done as „clean“ as possible, so no resampling or processing/interference of Windows must happen (the main reason of using ASIO).
But: since SWYH-RS usually captures Windows‘ default soundcard (and therefore captures/mixes/processes everything from system sounds to YouTube playing in the browser via the Windows mixer), my fear is, that still some „interference“ is happening. Will that happen, if I set VB-cable up as Windows‘ default soundcard?
So: is there a way to configure VB-cable (I guess Hifi-cable ASIO) in a way, that SWYH-RS „sees“ it, but limits the virtual cable input to ONLY the external ASIO D/A converter (which also acts as a high precision clock), leaving out everything else like Windows‘ mixer etc.
Thanks for bearing with this lengthy explanation and helping in the matter.
Looking for advice on „streaming bridge“ project
mg2c
