Problem upgrading to Voicemeeter 3.0.2.1
sjc-or
Post by sjc-or »
Hi, I was having issues with VBAN so decided to upgrade from 3.0.1.8 to 3.0.2.1. Unfortunately, now voicemeeter does not show up on my list of audio devices. The driver test shows these messages:
CHECKING VB-Audio VoiceMeeter VAIO : Not Installed
CHECKING VB-Audio VoiceMeeter AUX VAIO : Not Installed
CHECKING VB-Audio VoiceMeeter VAIO3 : Not Installed
So I tried de-installing and re-installing again and when I go to Windows Remove program, and click the de-install. I instead get the Install for 3.0.2.1 again. I think I need to somehow remove VM completely from the system and start a fresh install but am not sure how.
Help!
sjc-or
Re: Problem upgrading to Voicemeeter 3.0.2.1
Post by sjc-or »
OK I got this working by removing the driver and then re-installing VM. I have my original problem however but since it is related to something else, I will do a separate post.
There is already different topic about the subject:
GENERAL UPDATE GUIDE:
https://forum.vb-audio.com/viewtopic.php?f=6&t=87
Cannot Re-install Voicemeeter:
https://forum.vb-audio.com/viewtopic.php?f=6&t=381
VAIO / VB-CABLE Installation Checking:
Voicemeeter or Audio problem after WIN10/11 update:
https://forum.vb-audio.com/viewtopic.php?f=6&t=442
sjc-or
Post by sjc-or »
Yes, this is where I found the solution of removing the old devices. Thanks!
