contol a macro buton via android VBAN-Buttons
Posted: Sun Dec 19, 2021 12:00 pm
by gh0stless
Is is possible to control a Voicemeeter macro button via a button on the VBAN-Buttons app?
Re: contol a macro buton via android VBAN-Buttons
Posted: Thu Dec 23, 2021 1:29 pm
yes, you can use the following possible instructions:
Command.Button[i].State = 0; //(or 1) Change Macro Button State
Command.Button[i].StateOnly = 0; //(or 1) Change Button State only (without executing script)
Command.Button[i].Trigger = 0; //(or 1) Change Trigger Enable State
