Voicemeeter and Antelope Audio Thunderbolt not connecting
Brianrafe
Post by Brianrafe »
Hi, everyone. I have an Antelope Audio Discreet 4 Synergy core and using Thunderbolt. It works fine for my DAW (Cubase) but when I try to use in outside of my DAW in n Voicemeeter, it doesn’t work. I can find it in A1, but it just flashes in red and produces no sound.
I’ve reinstalled both Voicemeeter and the Antelope software and drivers many times but it still doesn’t connect. By the way, it works fine if I set it up with USB.
Any ideas what the problem could be?
Thanks,
Brian
Brianrafe
Re: Voicemeeter and Antelope Audio Thunderbolt not connecting
Post by Brianrafe »
Problem solved. It turns out my Thunderbolt driver was too new so I had to roll it back.
The_Nephilim
Post by The_Nephilim »
Well that is good you sorted it out..
