Macro buttons can have more than one trigger s?
I3ordo
Post by I3ordo »
Hello Mr Vb! i hope you are doing fine.
I have pshopped to illustrate what i had in mind, it was easy but wondering if it is easily possible to have this in VM...
It would make everything a lot simpler if a macro button could check more than one strips as "trigger".
I am already using button trigger enabler /disable commands that were newly added and i made them work but there are still times where things mess up so i thought maybe i should ask if it does not require structural changes ...
Re: Macro buttons can have more than one trigger s?
the workaround is to simply create 3 buttons maybe no?
