When I first start Voicemeeter Potato after I turn on my computer, all three virtual input strips (VAIO, AUX, and VAIO3) come up with the buffering set to 1536 samples (that's 0x600 in hex), and they're red. I can manually set them to larger buffers (2048 through 7168), which turns them from red to gray, but Voicemeeter does not remember those settings the next time I boot up the computer, and I can't find anywhere to set those buffers in persistent or saved settings.
Is there any way to configure Voicemeeter to start up with 2048 or 7168 sample buffers for the virtual input strips?
Virtual input strip buffering on startup
Re: Virtual input strip buffering on startup
this parameter is stored also for the driver, so in registry requiring administrator mode.
simply run Voicemeeter in administrator mode to make this parameter stored in registry.
(same remark if you change it by the related VBCABLE_ControlPanel app).
