32-bit vs 64-bit iinstall?
Snacko
Post by Snacko »
I noticed that my VB was in the Program Files(x86) folder and also looked at it's process in Process Lasso, which showed it was 32-bit. So uninstalled it, and then I downloaded the 'Installer' and it also installed again. The installer doesn't give me a choice of 32 or 64, so what's going on?
Do I need to download the zip to get the 64 bit? Just curious why the installer doesn't seem to have 64 bit..
UPDATE:
I just downloaded the .zip and see that it just contains the same? installer?? :roll:
How do I install the 64 bit version?
Thanks.
Re: 32-bit vs 64-bit iinstall?
Only Voicemeeter Potato exist in 64bits version, and it's installed in the same directory... listed in application list.
