Voicemeeter & FL Studio Focusrite
célérats
Post by célérats »
Hi I've a specific problem with voicemeeter
I need to share the DAW's audio to discord (via screen sharing or via input with VM) but the discord screen sharing doesn't detect any sounds when FL Studio is working with focusrite sound card.
I've trying to manage discord's input with VM but the sound is sizzles oddly slowed down modifying the sound return and therefore cannot be used / listened.
config:
16gb ram
focusrite 3rd gen solo
i5 9600 (cpu)
Thanks you
Re: Voicemeeter & FL Studio Focusrite
1- connect Voicemeeter to Focusrite ASIO driver: https://youtu.be/35N8hkOy8h4
2- connect FL Studio to Voicemeeter Virtual ASIO driver.
you can get inspiration from this video to configure discord (or zoom) with Voicemeeter Banana: https://youtu.be/nIpt3jF0Nds
célérats
Post by célérats »
This is not working :/
i cannot help more without screenshot... you may start by sharing screenshot of Voicemeeter and its system settings dialog box... then the FL Studio Audio settings Dialog box.
célérats
Post by célérats »
Np I send you some screenshots if you want more tell me :)
https://imgur.com/a/GbHlINM
apparently you have not watched our video tutorial.
1- if you select your focusrite ASIO driver as output A1 you must not select it as hardware input #1 with another interface (windows audio can disturb ASIO audio)... please select nothing as INPUT #1 and use the ASIO INPUT PATCH instead.
2- you configure FL Studio to use the same Focusrite audio device than Voicemeeter output A1 (usually ASIO driver does not like to be used by several app) ... that's why we asked you to connect FL Studio to Voicemeeter Virtual ASIO driver.
