No VBAN Host IP and no Ethernet Adapter
xGamerG1rl
Post by xGamerG1rl »
Hi there,
me and a friend try to set up a VBAN connection between two computers which are not in the same network.
We installed Voicemeeter on his PC and started VBAN. In difference to my VBAN, there is no IP in "Host". Only in "IP"
On my program, there is an IP in "Host".
and the IP is the same as the network-Adapter "vEthernet"
And on my friends computer there is no secound network-Adapter or the question to let the program pass the firewall... (like this Yes/No prompt)
We already added a Port-Forwarding into the Router and the Windows Firewall for the Voicemeeter program
Did we do anything wrong ?
(And yes, we searched like 1 Hour for the error (in this forum and on google) and reinstalled it multiple times...)
Re: No VBAN Host IP and no Ethernet Adapter
on your first PC, the Main Stream is OFF
it means you have not selected an output Device for Output A1
so there is no master stream, so nothing works.
xGamerG1rl
okay. We've selected an A1 Output.... But it's still not working :/ Did we set something wrong ?
after you need to configure and activate a VBAN stream.
IP HOST ADDRESS give IP Address of your computer, just use it on your other computer to send VBAN stream to it.
you don't need to hide your IP-Address on local network
192.168.x.x are local address.
xGamerG1rl
Yeah. I know. But we need the external IP to work because we're not in the same network :(
REM: if incoming stream = -none- it means your voicemeeter receive nothing.
if you receive 1 or several stream , you may right click on stream name field to popup the list of incoming stream (easier to select).
for a transmission over internet , thanks to read this topic:
https://forum.vb-audio.com/viewtopic.php?f=9&t=479
